try 4d63 40bit
try 4d63 40bit
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
yes i have seen 80 bit chip sometimes will fail and need to use 40 bit
weird but it happens
if not give up and let it go
car can also have problems with cluster i think and make it impossible to program without new cluster and system reset
Have a nice day.
I removed dashaboared i want read it by vvdi prog but i can't.prossessor 9s12hz256 mask 0l15y
Which programmer can read it please
And how can i reset dashoboard ?
First look for sleepyrz signature. You only ask on DK and no thanks and no info about problem solved or no.
scotlock (10th October, 2018)
i guess he did not try 40bits first
Have a nice day.
I tried program chip 4d 63 40 bit but the same problem
Also i tried reset dashoboard by zedfull
But it can't do
What is the problem please?
Best regards
Try using Ford IDS because ids show you the 10 minutes count down,if it says remove key an fail in less than a minute then the instrument cluster is corrupt.china tools usually damaged this type of cluster.
I removed dashoboard and i read it by vvdi prog it is ok
I made chip by tmpro2 sucsseful
Original chip it is 4d 60.I made King chip by tmpro and i tried To start a car but the led stays on
A little thanks goes a long way, thanks for trying to help is good, not many members will help if you ignore a bit of acknowledgment for the effort they giving. You say is 2009, 4d60 only goes to 2005, which one is it?
Manufacturer make System Program make add ILCO Strattec Alternate TRANS Year(s) Model first transponder dup add'l key blanks ID key First Key key key
2012-13 Focus yes 4 button IKT side mill yes yes yes OE 164-R8046 5921709 4D63 2012-13 Focus yes side mill - plain yes yes yes OE 164-R8060 5915237 4D63 2012-13 Focus yes 4 button PEPS fob yes yes yes OE 164-R8091 5921285 2012-13 Focus yes 5 button PEPS fob yes yes yes OE 164-R8092 5921286 2012-13 Focus Emerg Key - no transponder 5923267 2008-11 Focus yes Ford 3 Button IKT "SA" yes yes yes OE 164-R8070 5912560 2008-10 Focus yes Ford 4 Button IKT "HA" OE 164-R7040 5914457 2008-11 Focus yes PATS 5 CAN yes yes yes H84PT 5913441 4D63 2006-07 Focus yes PATS 3 CAN yes yes yes H84PT 599114 5913441 4D63 2005 Focus yes PATS 3 CAN yes yes yes H86PT 691643 4D60 2003-2004 Focus 2.0 yes PCM yes yes yes H86PT 691643 4D60 2003-2004 Focus 2.3 yes PATS 3 CAN yes yes yes H86PT 691643 4D60 2000-2002 Focus yes PCM yes yes yes H86PT 691643 4D60
Have a nice day.
LED light staying on generally means programming is still open on car- need second key registered to car to close.
100% chip is 4d-63 (40bit)
Many aftermarket and cloned chips will not work for programming. Try to use an oem, Ilco or strattec key.
I recommend clear/erase function that way you cant test different chips without needed to do security wait each time.
is bad or you need to do parameter reset because of issue's with PCM.
i wait it but the same problem security light stays on ,maybe my problem the original dump of dashboard it is damaged
can you repair it please
