Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    Sep 2016
    GB
    Default What key ref for golf 4
    Hey, how to know what key ref number to buy for a golf 4? What part number must i read with vcds to know what key can be matched?
    Thank you
    p1et's Avatar
    Oct 2013
    You mean remote? Depend on year of production.
    1998-2001 - 1J0959753 A/N
    2002- 1J0959753 CT / AG
  3. The Following 3 Users Say Thank You to p1et For This Useful Post:
    andreia67 (5th September, 2020), mrnixdorf (9th October, 2018), ramiz auto lock (11th October, 2018)
    Sep 2016
    GB
    Quote Originally Posted by p1et View Post
    Thx, its a 2002 model, tried the 1j0959753ct 2 buttons, wont go for programation
    In vcds
    I have 0 instead of 1 in field 3... By following this:
    Select]
    [17 - Instruments]
    [Meas. Blocks - 08]
    Group 022
    [Go!]The value in field 3 must be 1. If value is not 1, the key is not capable of being adapted to Immobilizer.
    For more info, the car was immo off start with a key without transponder, switched to immo on and trying to program a new key without success
    Sep 2016
    GB
    I would appreciate any help guys
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by mrnixdorf View Post
    about what?
    you need programming remonte or immo?
    you have pin code?
    Oct 2015
    for remote programming enter in 46(central conv...) than choise channel 1 for addaptation.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  8. The Following User Says Thank You to rokibar For This Useful Post:
    EMCE159 (13th October, 2018)
  9. #7
    Sep 2016
    GB
    the key won't be programmed, i got the pin code
    i'm trying to program the key when immo on not off
  10. #8
    Sep 2016
    GB
    Anyone experienced the same issue?
  11. #9
    Aug 2015
    your vcds clone is bad...
  12. The Following User Says Thank You to dtip For This Useful Post:
    mrnixdorf (13th October, 2018)
  13. #10
    Sep 2016
    GB
    Quote Originally Posted by dtip View Post
    Will try using another vcds or vag tacho and see
  14. #11
    Aug 2015
    i don't think vagtacho will program your remote... i would better advise you tu use manual remote programing procedure for golf 4, google it...
  15. #12
    Apr 2016
    uk
    Are you using the right transponder? Brand new id48?
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  16. #13
    Aug 2015
    it does not mater, immo and remote part does not have anything to do with each other on golf 4. he is trying to add remote
  17. #14
    Sep 2016
    GB
    Im following this tuto using vcds
    http://wiki.ross-tech.com/wiki/index...hing_(Cluster)
    But on this part :
    Select]
    [17 - Instruments]
    [Meas. Blocks - 08]
    Select Block 022.
    [Go!]
    You can check each key in this manner.
    I have 0 on field 3 not 1, thats mean the key wont be programmed, the bad thing is that i have only this new key, i dont have other keys to test or transponders.
  18. #15
    Sep 2016
    GB
    Im trying to program the key for immo not for remote, and yes the key is new
