Results 1 to 4 of 4
    Dec 2017
    Default Audi A3 8P 2.0TDI Cranking not start
    Hi everyone,
    I have problem with Audi A3 8P Quattro year 2005, 2.0TDI. The owner said that immediately after the purchase the car started and the alarm went off (siren only).
    After 2 weeks the car did not start, no cranking, and the siren was on. I found an alarm in the car Defa Can 800 and dismantled it. It was connected only to the sensors and the central lock . Starter kill wasnt connected.
    There was also a module in the car Tele Comfort GSM Callstarter connected to webasto (adding, not original). I dismantled it too.
    Now car cranking but not start. I have connection by all modules via VCDS. No errors related to communication, IMMO is OK.
    I looking for schematic of ECU, and relays need it to start the car.
    Best regards!
    rafal's Avatar
    UK - PL
    have you tried start car with autostarter spray?
    need help
    now my goal is to buy xp-005
    who will help?
    Meat-Head's Avatar
    If immoboliser from factory then start, run die
    check screws in under hood fuse box
    Dec 2017
    Screws are correctly grounded.
    Immo is original. Car only cranking.
    EDIT: Solved - fuel system
