Results 1 to 10 of 10
    Oct 2018
    Default Mercedes w211 2003 E200 1.8 kompresor
    Hi, please help off the lambda
    Siemens SIM4L KE
    Bllinda's Avatar
    Baltic
    try .... ....
    today
    A topic that interests me
    Oct 2018
    Thank you very much Bllinda !!
    Oct 2018
    I upload
    I uploaded the file you sent and it does not work.Start the engine fan to the maximum.
    I uploaded the file you sent and it does not work.Start the engine fan to the maximum.I uploaded the file you sent and it does not work.Start the engine fan to the maximum.I uploaded the file you sent and it does not work.Start the engine fan to the maximum.
    Oct 2018
    I wrote the file sent by (Bllinda ) and does not work.
    When switching on the ignition switches on the engine fan.
    Mar 2013
    Europe
    I uploaded the file you sent and it does not work. Start the engine fan to the maximum.
    Resolder your Flash in ECU 29FX00
    Car Running FAN of Maximum? ---> Car cant find ECU!!!
    Your MOD File with Ckecksum?!
    Oct 2018
    When the ignition is switched on, the car's fan starts to its fullestWhen the ignition is switched on, the car's fan starts to its fullest
    Oct 2018
    When switching on the ignition switches on the engine fan. starts to its fullest
    Oct 2018
    Siemens SIM4L KE
    Oct 2018
    Is there anyone who can help me with lambda off ?
