Results 1 to 7 of 7
    Apr 2016
    uk
    Default Keydiy hu83 blade
    Hi people
    Today I had a problem with a keydiy hu83 blade..
    I cut the key and did not fit in the door lock. Just did not went entirely inside the lock. Tried to force it but no luck.
    In the ignition worked well..
    After that I've cutted a China key and everything fine..
    Car was Peugeot 308 year 2008.
    Anyone had this issue?
    I could find only one kind of hu83 keydiy.
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
    rob h's Avatar
    May 2011
    I have made some. They were all ok.
    Upload pictures, of the correct and incorrect key.
  3. The Following User Says Thank You to rob h For This Useful Post:
    comizelu (13th October, 2018)
    Apr 2016
    uk
    I don't have pictures
    Customer did not agreed..
    Quote Originally Posted by rob h View Post
    Keys was decoded and both cutted(cinese and keydiy blade) from same reading with xc-mini..
    Maybe factory made wrong.. Will try to order others.
    Thanks Rob
    newone's Avatar
    Oct 2016
    sometimes i have also issues with keydiy blades,last time was with a va2,cut then a silca fh and was all ok,needs a bit of modification to fit in plus 3x the money but those works great every time.
  6. The Following User Says Thank You to newone For This Useful Post:
    comizelu (14th October, 2018)
    Top Poster ramiz auto lock's Avatar
    Nov 2017
    NORTH LONDON
    Same here the only blade from key diy i had problem with was va2 other than that all good so far.
    Mabe the blade that you used was a faulty one.
    Sent from my SM-G925F using Tapatalk
  8. #6
    rob h's Avatar
    May 2011
    Most likely bad cut of the tip.
    If insertion in doorlock is bad.
    I measured the keydiy batch, the are all fine.
  9. The Following User Says Thank You to rob h For This Useful Post:
    comizelu (15th October, 2018)
  10. #7
    metallo's Avatar
    Jun 2018
    Italy
    Suzuki and mazda blades are similar but different on the tip you should grind it a bit
  11. The Following User Says Thank You to metallo For This Useful Post:
