Audi 100 C4 no start, but does crank
Results 1 to 3 of 3
    Feb 2018
    Default Audi 100 C4 no start, but does crank
    Hi all!
    Audi 100 C4 is not starting after erasing DTCs (Airbag module). It does crank and the immo light on the dashboard is off.
    Not sure if it can be an immo problem but it looks like it is.... I cannot acces the immobox, coding = 0 (according to FVDI)
    Can someone suggest how to test if it is an immo problem or not? Any suggestions?
    IMMO type: 4A0953234F
    ECU: 8D0907557F
    Was planning to make a dump of ECU and program IMMO off. But I was wondering of that is the right thing to do
    In EEP
    no immo off solution use julia emulator for this ECU
    Meat-Head's Avatar
    If immo then would expect start, run, die.
    use diagnostic tool to check rpm signal then look at fault as if old old car, check for fuel, spark, lumpy stick belt snapped
    its only uno fawlt
