Results 1 to 15 of 22
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Default Cruise control don't work after tune
    Hi people,
    I tuned citroen berlingo 1600 hdi with edc17c60 ecu
    Read boot with ktag, write, and after this cruise control don't work.
    Anyone idea? Is there any module damaged like frm module on bmw cars?
    Or is possible on software? Corrupted?
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    DK Veteran daniel guerra's Avatar
    Didn't you touched any switch by mistake?
    Regards,
    Sep 2018
    touched IQ x Nm maps¿
    sdtsedat's Avatar
    Jan 2015
    Belgium
    In mpc is cruise control??
    Is possible?
    Next answer
    Iq to nm??? Yes i touched, whats wrong with this?
    No need to touch this map in edc17c60?
    Sedat Garip
    Belgium
    With Kind Regards,
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    need with lexia now to be activated after remap, like in renault after remap crusie control not working neede with can clip to be activated again
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Pfff i dont have this, and customer come back tomorrow morning, no idea what to do..
    Is it good idea to try it with ori? Or no waste my time?
    Sedat Garip
    Belgium
    With Kind Regards,
    AVDigitale's Avatar
    Apr 2017
    the same
    i tried many times and with ori not working again ,you try maybe work in PSA cars ,in renault not work
    File Service
    sdtsedat's Avatar
    Jan 2015
    Belgium
    What is reason?
    Sedat Garip
    Belgium
    With Kind Regards,
    Meat-Head's Avatar
    Can you get live data for clutch and brake switch
    also try for test 3rd gear like 3000rpm try cruise
    what year is car?
    do ALL brake lights work?
    any fault codes?
    pike's Avatar
    Sep 2013
    it is quite possible that cruise maps are affected by changes in tune file.
    sdtsedat's Avatar
    Jan 2015
    Belgium
    I try now write ori back and see if works. We have egr fault with check engine light.
    Sedat Garip
    Belgium
    With Kind Regards,
    Myjector's Avatar
    Dec 2017
    Sedat, Did you switch off the cruise control and speedlimiter switch before you remove the battery/ecu?
    Try write ori back thru obd and switch cruise control on and off @ the end of the writing before you cut off ignition
    AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
    FULL SWIFTEC AND EVC RESELLER
    FILE SERVICE FROM 8AM - 9PM 7/7
    BAPRO 4WD DYNO
  13. The Following 2 Users Say Thank You to Myjector For This Useful Post:
    pike (15th October, 2018), sdtsedat (15th October, 2018)
  14. #13
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Hmm.. I din't tryed, but battery was not disconnected. I write ori back, but same situation.
    Sedat Garip
    Belgium
    With Kind Regards,
  15. #14
    Nov 2013
    Lietuva
    Quote Originally Posted by sdtsedat View Post
    there is your problem
    OPEL / SAAB EDC15M * PSG16 * EDC16 * EDC17 * DENSO * ACDELCO cloning / programming / resetting
  16. #15
    sdtsedat's Avatar
    Jan 2015
    Belgium
    If car give dtc, cruise control don't work?
    Sedat Garip
    Belgium
    With Kind Regards,
