Enybody know the solution for Vaux - com china clone 1.99 fw or 1.59 fw to make it running ? Because for interfaces and both software then I connect interface scelect car and like engine chose engine everithing is fine but then program reads engine it like freezes or crashes. Then I try to read falut codes it says that the ecu is busy or no comunication on Mesure blocks there is no readings everything empty. But with op-com 2010 software all works fine..... Can someone help !!!! Thanks guys !!!!!
