And next to the MCU is 95,1,60. What is part,number CIM?
Im trying read a cim module with vvdi prog, i select immo and astra, this show the pinout in pcb, when i press in read id, this show succes Mask:1L59W ID:0115, but when i press read this show a message, this chip needs to crack. Chip crack failure, please confirm the chip type and connection right, then try again !. I will upload the pinout, all conection was revised and resolder.
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
carsandkeys (16th October, 2018)
solved, boring of try read i swap mcu and write eerpom.
with carprog full you do it in 5 minutes.
Small circumstances produce great events : 02.47-tranquillité:
