Results 1 to 8 of 8
    Sep 2015
    Default need help with immo placement for rav4 2010 smartkey
    Would anyone know the immo placement for this one?
    immo part no is 89070-42131
    immo cant be reset with zedfull mvp or abrites and cant find the damn box.
    thank you for your help.
    ray-ray's Avatar
    Your programmer are not communicate with the immo.? Good battery and do ecu & immo. Sync. With 4/13 grounded for 35min. Then try to communicate make sure key is turn to “on” with the Drivers Door open.
  3. The Following User Says Thank You to ray-ray For This Useful Post:
    s5oslo (16th October, 2018)
    Sep 2015
    Sadly that didnt work.
    Also received another toyota today, avensis 2009, same problem.
    on both cars abrites just says immobliliser unknown.
    avensis vin: SB1BD76LX0E001428
    rav4 vin JTMBC31V20D013529
    both are 2009 model
    battery is fully charged on both cars.
    if anyone has any other ideas, let me know.
    Abrites is also fully updated btw.
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Behind the central console with navi, deep, close to the triangle shaped cross-rods. Or in IT. Sometimes you can found IT only if you look trough the unmounted glove box's place.
  6. The Following User Says Thank You to PocketHero For This Useful Post:
    s5oslo (17th October, 2018)
    Birmingham
    I had Avensis 2012 tell me unknown immo. I went into diagnostics and used the button in there to reset and it worked fine.
  8. The Following User Says Thank You to MarkPRP For This Useful Post:
  9. #6
    Sep 2015
    Ok im at a total loss here. found what I though was the right box 89784-42031 but it contains a 93c46 chip and i was expecting 93c66 or 93c86, so i assume this bos is just for keyless function? if anyone can shed some light on this i would be most greatful. VIN JTMBC31V20D013529
  10. #7
    Sep 2015
    Quote Originally Posted by MarkPRP View Post
    Tried but didnt help. thanks though
  11. #8
    Sep 2015
    Ok this one is solved now.
    The box I was looking for was OSCILLATOR, DOOR ELECTRICAL KEY
    with part no 89991-30050 so that was a suprise
    it now starts, and remote and keyless also work (also to my suprise)
