What's wrong with your dump?
i need an eeprom dump from a GID display from an Astra H. But should be from a GID type BM Part number: 13275953 (Siemens VDO)
From this display:
Someone can share a eeprmom dump? (chip 93c66) KP and SE GIDs not valid.
Thanks so much!
Upgrade OK to 3 Lines:
KP in HW 5.20 Tested by me
SE in HW 5.20 Tested by bank
Vins for upgrade in SPS:
W0L0AHL35A2092407 > Valid
W0L0AHL6795006621
In the eeprom, edit:
replace 00C80F7B (for KP GIDS) with 00CA9331 (two times)
and KPKP to BMBM
replace 00C916CA (for SE GIDS) with 00CA9331 (two times)
and SESE to BMBM
Thanks exe123 for this info!
ArbeGTC (15th October, 2018)
hi!
I need the eeprom from a BM type for testing with GlobalTIS the SPS (Service Programming System)
I cant find a BM GID (cheap) to buy them and test.
You just need to modify partnumber and ident inside your dump and use SPS with the correct VIN to update.
replace 00C80F7B with 00CA9331 (two times)
and KPKP to BMBM
I think you'll receive something like that:
Tested and works fine on KP. SPS just checks partnumber and ident from eeprom of VDO GID
I was trying to update KP, SE, AT, BG without success
I think VIN also is needed.
I'll try again...
Of course you will need correct VIN. Search on ebay for partnumber of BM display. Most german parts vendors will write also VIN of the scraped car.
VINs for BM:
W0L0AHL35A2092407 Found in: https://www.varaosahaku.fi/fi-en/Sea.../OEM-13275953/
W0L0AHL6795006621: Found in: https://www.ebay.es/itm/Bordcomputer...XtIO:rk:2:pf:0
Well, after mod the eeprom of the GID. now SPS shows the GD83 software to update. But in tech2 remote, java crashes....
i will try in pass-tru mode (J2534 Tech2)
Vin used in eeprom and SPS: W0L0AHL35A2092407
GID upgraded successfully. 2 Lines (GD59) to 3 Lines (GD83)
GID KP in HW 5.20. Edited the P/N like as a BM GID display
Thanks to all!!!!!!
