i do immo off with otochech, try and letme know
Hello
Please help to immo off the IAW 48P.11 ECU
Car has been with varius mechanics and no solution, and now the immo information from 29F200 flash is filled with FF (from 04000 to 07FFF)
I upload original file from the same car and software from this forum. Can someone help to real immo off?
Is it possible to completely immo off this car?
Thank you
Which option have you used? Was it IAW 48P.10? but my car is Peugeot 406 IAW 48P.11.
Does someone knows if this solution works on 48P.11 ecu?
Thank you all
read and post eeprom as well
need help
now my goal is to buy xp-005
who will help?
Here it is Original EEprom and Flash (remember flash was virginized by someone, at the begining of this thread I added original file from other ECU.
Thank you for any help
here you go. report back
need help
who will help?
Will test in 3 days tops.
Need to cut anything?
Thank you
A friend here is your immo off 100% !!!!! There are no restrictions in work! The engine works like a clock!
on average cut f3 connector
thank you if I helpedgratitude motivates me to help further
Alexeyhs4 (27th March, 2021), bangreno (20th February, 2019), bms971 (3rd April, 2019), Ermakbrat (21st November, 2018), jah83 (13th January, 2023), Krzychu92 (3rd May, 2023), luxervol2 (9th May, 2022), Multek1 (27th March, 2021), nokwueze (8th December, 2020), Norek (19th August, 2019), scania144 (21st August, 2021), tedjani (5th September, 2021)
Thanks for dump
Rafal solution did not worked. Thank you anyway.
Or should I have cut a wire?
