Results 1 to 10 of 10
    Apr 2013
    Default Peugeot 406 IAW 48P.11 IMMO OFF help
    Hello
    Please help to immo off the IAW 48P.11 ECU
    Car has been with varius mechanics and no solution, and now the immo information from 29F200 flash is filled with FF (from 04000 to 07FFF)
    I upload original file from the same car and software from this forum. Can someone help to real immo off?
    Is it possible to completely immo off this car?
    Thank you
    Oct 2018
    Roma
    Default try this
    i do immo off with otochech, try and letme know
    Apr 2013
    Which option have you used? Was it IAW 48P.10? but my car is Peugeot 406 IAW 48P.11.
    Does someone knows if this solution works on 48P.11 ecu?
    Thank you all
    rafal's Avatar
    UK - PL
    read and post eeprom as well
    need help
    now my goal is to buy xp-005
    who will help?
    Apr 2013
    Here it is Original EEprom and Flash (remember flash was virginized by someone, at the begining of this thread I added original file from other ECU.
    Thank you for any help
    rafal's Avatar
    UK - PL
    here you go. report back
    need help
    who will help?
    Apr 2013
    Will test in 3 days tops.
    Need to cut anything?
    Thank you
    dodge69's Avatar
    Mar 2012
    Belarus
    A friend here is your immo off 100% !!!!! There are no restrictions in work! The engine works like a clock!
    on average cut f3 connector
    thank you if I helpedgratitude motivates me to help further
  9. The Following 14 Users Say Thank You to dodge69 For This Useful Post:
    Alexeyhs4 (27th March, 2021), bangreno (20th February, 2019), bms971 (3rd April, 2019), Ermakbrat (21st November, 2018), jah83 (13th January, 2023), Krzychu92 (3rd May, 2023), luxervol2 (9th May, 2022), Multek1 (27th March, 2021), nokwueze (8th December, 2020), Norek (19th August, 2019), scania144 (21st August, 2021), tedjani (5th September, 2021)
  10. #9
    Mar 2018
    Thanks for dump
  11. #10
    Apr 2013
    Rafal solution did not worked. Thank you anyway.
    Or should I have cut a wire?
