Results 1 to 10 of 10
    Nov 2010
    Default bmw.mini Cas3 corrupted
    Hi all, I have a corrupted Cas3 that I need repairing. The car come to me after a customer had a spare key programmed. The cas wouldn't respond and the keys were not accepted so the ignition wouldn't turn on. I with a bit of help managed to reflash the cas but there still seems to be a problem with the bootloader. I have read the flash and eeprom which is attached, if someone can help me fix it that would be great.
    Dan
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by mscauto View Post
    Dan
    This file is coded this is CAS3 +
    try this eeprom, if this does not pass then you must read eeprom of DME and you must find ISN of DME.
    This is my opinion, but I hope someone else will help you
    ISN : FE646E095DCFD7AB79CBA14EE35E533C
  3. The Following User Says Thank You to macako6 For This Useful Post:
    mscauto (15th October, 2018)
    Mar 2016
    POLAND
    Try this , your file repaired.
  5. The Following User Says Thank You to 81zx For This Useful Post:
  6. #4
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by 81zx View Post
    It's the same file
    Mar 2017
    France
    hi
    your eeprom file is not corruppted
    but for the flash i dont knew
    regards
  8. The Following 2 Users Say Thank You to omarino For This Useful Post:
    macako6 (15th October, 2018), mscauto (15th October, 2018)
  9. #6
    Nov 2010
    Is there a problem with my eeprom? Has it been modified? I cant check until tomorrow as I left my other laptop at work.
  10. #7
    droidwayne65's Avatar
    Aug 2015
    North America
    Dan
    What's the part number?
  11. #8
    Nov 2010
    Quote Originally Posted by droidwayne65 View Post
    Hi the part number is:
    9147221
  12. #9
    Nov 2010
    If I get another flash from the same part number CAS would this work? Or is there something in the flash that would stop me doing that?
  13. #10
    macako6's Avatar
    Mar 2015
    maybe you will find your solution here
    http://www.digital-kaos.co.uk/forums...-flash-9147221
