Mini cooper 65.77 - 9122500-01 Internal control unit fault.
Results 1 to 4 of 4
    Sep 2015
    Planet Earth
    Default Mini cooper 65.77 - 9122500-01 Internal control unit fault.
    Hello guys, can someone please help me repair this fault code in this ecu?
    Car is Mini Cooper R53 2006
    Airbag module: 65.77 - 9122500-01
    EEPROM: 95640
    Fault: Internal control unit fault.
    Thank you in advance.
    Don't Forget to Rep + Thanks If I helped you
    Sep 2015
    Planet Earth
    @dragon100 have solution for this my friend?
    Sep 2015
    Planet Earth
    Problem solved guys thank you
    Apr 2019
    Quote Originally Posted by mikedemirjian View Post
    EEPROM: 95640
    do you have the wiring/pin diagram how did you manage to read out the eeprom thanks
