Results 1 to 15 of 16
    super jumbe's Avatar
    Livingstone
    Default POLO 2014 ALL KEYS LOST
    Any one-programmed polo 2014 all keys lost, AVDI not recognizing, checked chip on dash big chip, has any one done lost keys any help very much appreciate.
    scotland clydebank
    have you got handy baby obd assistant i think this can be done with it i have not tried myself but no risk if you have it .
    May 2013
    I've come across some 2014 VWs which have MQB clusters so can't do all keys lost
  4. The Following User Says Thank You to Carkeysa For This Useful Post:
    super jumbe (18th October, 2018)
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by super jumbe View Post
    If you can extract CS and PIN from ECU, then install VDO cluster, synchonize , and add key
    This is PQ car , not MQB
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
    Oct 2014
    Netherlands
    Any proper tool with suitable license should be able to read immo data from Polo 2014 PQ.
    Then the next step is learning new transponders, also no issue normally.
    Jun 2018
    England
    24c64 under the clocks?
    If i helped please press the thanks button
    Oct 2014
    Netherlands
    2014 Polo PQ should be 24C64.
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by H2Deetoo View Post
    2014 Polo is eeprom less
  10. #9
    Livingstone
    I did opened the cluster and I did not see 24c64 chip but I saw this big MQB chip and no tool has software to extract information at this stage, look I can not risk on theories I need to see some one succeeded programming lost keys, and handy baby asking for working keys on stage 2, as far as I have been told only dealers...
  11. #10
    Fallen's Avatar
    2014 6R polo with VDO cluster can be done.
    Remove cluster, remove LCD screen and 24c64 will be under there.
  12. The Following 2 Users Say Thank You to Fallen For This Useful Post:
    doctore (18th October, 2018), paul_12345 (18th October, 2018)
  13. #11
    Sep 2016
    When door lock have key hole horizontal then its 2015 model. When vertical you can do like 2013 without any issue.
  14. The Following 2 Users Say Thank You to qeso705 For This Useful Post:
    p1et (18th October, 2018), super jumbe (19th October, 2018)
  15. #12
    Oct 2014
    Netherlands
    Polo PQ cluster always has 24C64!
    Polo MQB cluster hasn't got eeprom!
    Please be specific and post full partnumber and SW version (or picture of label)
  16. The Following User Says Thank You to H2Deetoo For This Useful Post:
    rob h (19th October, 2018)
  17. #13
    Livingstone
    Quote Originally Posted by qeso705 View Post
    Yes door lock key hole was horizontal 2015 model even key blades are smaller then the 2013-14 polo and I still can not even find new blades for that car let along programme keys.
  18. #14
    Mar 2017
    Australia
    Blades are Silca HU162T futura can cut them with correct adapter jaws maybe some other key machine also.
    I have done AKL on 2014 Polo with AVDI service mode by dump, after SuperVag failed to put into service move with pogo pin. However, the one I did was on HU66. Sounds like this one is MQB?
    Can you post a pic of rear PCB of cluster?
  19. #15
    westville locksmiths's Avatar
    Sep 2011
    South Africa.
    bianchi 994 with new software also cuts keys
