    South Africa
    Default Autoboss v30 missing some OS files
    Hi please, can you share the.exe files found in the root directory of your sd card for the V30. I have version 3.4.Thanks,regards
    Do what you can with what you have .
    South Africa
    It is a very easy and simple process, remove sd card from the machine ,insert it into laptop sd card reader ,read it and save,return sd card to the machine and post saved file to me please,easy peasy,thanks ,regards
    South Africa
    Thanks I came right with the files ,regards
    South Africa
    Default exe files
    the files i copy from my autoboss
  5. The Following 2 Users Say Thank You to frikki For This Useful Post:
    ecufix (17th October, 2018), vanos batam (24th September, 2019)
    South Africa
    All of the above was to correct the touch screen calibration with no success, any ideas on how to connect a mouse using the serial port?
    Nov 2018
    Have u the last update of autboss v30 ??
    Envoyé de mon HUAWEI NXT-AL10 en utilisant Tapatalk
