Hello
you have to do a synchro of the pats
Hello
Small circumstances produce great events : 02.47-tranquillité:
Ive tried initialising PATS through IDS is synchro different?
control ring and your two key, if ok, posted eprom dash + ecu
what programme do you use for eprom. Sorry im a complete novice
Do the sync first, should take 10 minutes to complete if you have the right equipment.
here's some info hope this can clarify your problem not complicated since you're a newbie. https://www.troublecodes.net/p1codes/p1259/
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
Sync with ids?
Sent from my SM-G930F using Tapatalk
Before you do anything as far as reprogramming any module/keys. If your car did that on its own or maybe after a low battery issue, just try to unplug the battery for 10 minutes, plug it again, put a charger on it, turn the key on with an original key, check/delate codes, leave ignition on for at least 2 hours and then try to start the car normally. Hopefully will re-sync on it’s own. If not, you can try to reprogram pats (2 keys)
Ok I'll give that a go first, thanks for the reply's.
Right tried disconnecting battery then leaving ignition on with charger for over 2 hours. Still nothing.
