Results 1 to 12 of 12
    Jul 2018
    Default CD70 Navi & CID KS
    Hi, i want to upgrade my CD30MP3 & GID with CD70 NAVI & CID.
    I have bought on internet, but there aren't unregistered before...
    i need to unregister for programming with my car code.
    CID is KS version(93c66),CD70(24c64).
    All dumps attached.
    Thanks!
    bank's Avatar
    Feb 2017
    Ukraine
    Code from CID is 0010
    CD70 looks like unregistered
    Write zeros in 1DE-1EF and DIS will be unregistered
  3. The Following User Says Thank You to bank For This Useful Post:
    lolitoxx (16th October, 2018)
    Jul 2018
    Many thanks!!
    For set my carpass on CID need to:
    -mount it on my car
    -connect opcom
    -disable antitheft with 0010 code
    -enable antitheft with my carpass
    Right?
    Thanks!
    Jul 2018
    There?
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by lolitoxx View Post
    Many thanks!!
    -mount it on my car
    -connect opcom
    Right?
    Thanks!
    Nope
    -mount it on car
    -connect opcom
    -chech Mid Speed CAN Bus configuration (ECC, DAB, UHP - should be correct for your car and the same for DIS and EHU), correct it if it needed
    -enable antitheft with 0010 code via EHU
    -disable antitheft with 0010 code via EHU
    -enable antitheft with your carpass
  7. The Following User Says Thank You to bank For This Useful Post:
  8. #6
    bank's Avatar
    Feb 2017
    Ukraine
    There?
    No, try again )
  9. #7
    Jul 2018
    Sorry, wrong dump...
    There
  10. #8
    bank's Avatar
    Feb 2017
    Ukraine
    There
    No, try again.
  11. #9
    Jul 2018
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by bank View Post
    Try to read this again
  13. #11
    Jul 2018
    for unregister CID i need to set this offset(1DE-1EF) to 0
    Last question...Can i mount on my Astra H dvd100 navi with this CID KS?
  14. #12
    bank's Avatar
    Feb 2017
    Ukraine
    Yes, in CID, not it CD70
    Yes
  15. The Following User Says Thank You to bank For This Useful Post:
