Hello friends, i have car audi a4 allroad with fault codes related to passenger aibag disable switch.
problem is this car does not have any passenger disable switch installed, i think someone have changed coding for it, is it possible to change long coding to disable passenger airbag disable switch? my vcds does not give any help about coding this module, thanks!
Control Module Part Number: 8K0 959 655 G HW: 8K0 959 655 G
Component and/or Version: AirbagVW-AU10 H39 0560
Software Coding: 30343435363030303030554A304C384B3053
Work Shop Code: WSC 06335 000 00000
ASAM Dataset: EV_AirbaECUVWAUDI010 003010 (AU48)
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4188C607D0E5D649A6-8014
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [137] - Open or Short to Plus
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [137] - Open or Short to Plus
