for this use it's better not to risk,you need to open it and read/write in bdm with ktag
I was wondering about remapping this car:
MPPS INFO: (read write only in the car) leave key off for at least 3 min after prog)
KESS INFO: On some types of ECU it need to be needed to recode the encoding of the injectors through a diagnosis tester.
We recommend not turning on the engine after programming and wait till dash completely off.
Any more info?
Can we disable this in the MAP?
Kess read and write this without problem by Obd.
After write you must wait 3 min with ignition off and 2 min with ignition on then car start.
Wysłane z mojego SM-G965F przy użyciu Tapatalka
kess and mpps work fine on edc16C34 if you respect procedure,tested.
Kess works fine, and write very fast to, faster than X17
But if you feel not safe, take a bdm full read first.
Cut off ignition for about 3 minutes.
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
its EDC17C10 / 60...
Kess says its normal OBD
Only Autotuner does them OBD.
But if you have an ktag clone you can do EDC17C10 in boot, easy connection
BAPRO 4WD DYNO
