Do it via DAS. Not need to reflash this ECU.
Hi i made dpf off for this ecu delphi CRD 2 with swiftec,dpf is off but mil lamp is blinking.before write mod,i did reset dpf soot counter with autocom,don't have star diagnose.Everything works OK dpf is off but mil is blinking,no faults in ecu tried to disconnect dpf sensor but still the same.Is there any procedure maybe with star before writing mod
i know but don't have DAS
So, Swiftec and ASC remover did this ECU with MIL blinking. Only manual solution.
delphi ecu always with manual solution needed swiftec and other not working good
but you can try with benz star diagnostic to reset again dpf and soot and to try
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
solution is :
Update ecu software with SD
Some SW dont work even with manual solution!
P2bac fault!
When you delete this fault from DTC list, you get P0000
Probably star diagnose dont give any DTC but generalt protocol in autocom see P0000 or P2bac.
Upgrade SW with SD and than read file again.
Also always reset DPF with ori file.
Its common problem.
DSG TUNING
File Service
ivanmihov (17th October, 2018)
