Results 1 to 6 of 6
    Jun 2018
    England
    Default Damaged 24c64 eeprom on vw polo 2011 vdo cluster
    i have been given this cluster and it looks like someone has been playing and the prom is damaged, is there anyway to put a new prom on the cluster and learn back to the car
    Cheers
    If i helped please press the thanks button
    Oct 2014
    Netherlands
    Sure, that's normally no problem if you have the right tools, and you can find a matching (or similar) dump. Post full partnr and software (SW) version.
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    paulsta (17th October, 2018)
    Jun 2018
    England
    Here is dash info
    Thanks again
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Its a hard job évén if u put an other dump the car will not start because every dump have spécial encryption u need to Immo off your écu and program your keys again and make what we call Coding to match vin and pin... Etc
  6. #5
    Maartinj's Avatar
    Nov 2010
    Poland
    Quote Originally Posted by paulsta View Post
    Here is dash info
    Thanks again
    via epp dump you can only "wake up" cluster , then to program / fix internall error , need proper tools
    I can fix it even if no epp, I can make it virgin ready to program
  7. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    brend (17th October, 2018), galaxy0634 (18th October, 2018)
  8. #6
    Oct 2014
    Netherlands
    As said already there are 2 ways to fix this cluster.
    First write a valid dump, then either make it really virgin so it can be adapted with ODIS, or try to read missing immo data from engine ecu and learn transponders.
  9. The Following User Says Thank You to H2Deetoo For This Useful Post:
