Results 1 to 5 of 5
    Default Skoda Octavia AC problem
    Hello, I have Skoda Octavia 2015. with AC problem. I turn on heating and it works on driver side, but passenger side blows cold. No fault code in memory, anyone knows what could be the issue?
    Jan 2018
    It is necessary to replace the heating radiator
    If My Post Was Helpful
    Than Please Click On Thanks & Rep..
  3. The Following 2 Users Say Thank You to filez79 For This Useful Post:
    RedNix (18th October, 2018), yahia1908 (10th December, 2018)
    bidu20's Avatar
    Jun 2016
    I think its a problem from Air adjustment flaps?
    Don't forget the magic button !
  5. The Following User Says Thank You to bidu20 For This Useful Post:
  6. #4
    I haven't tried adaptations. Can any of the motors be problem or what else can cause the problem? Regards
    Jul 2016
    Vilnius
    Any history of coolant replacement? (E.g. timing belt, water pump or EGR cooler replacement, crash accident, etc).
    First of all, check the temperature blend doors (flaps) for proper operation.
    Secondly, if the above is fine, mos tlikely the problem is clogged heater core. It's a pain to replace it... You can try to (back)flush it with some garden hoses before attempting to replace it.
    If you will be flushing it with tap water, be sure to drain the system afterwards thoroughly, fill in with just distilled water, run the car for a few days, then drain, fill with only distilled again. Run for some more days.
    Only after the above has been done, you can refill with coolant. I'd suggest making a concentrate to -45 *C for such setup. The remaining distilled water in the system will dillute it and in the end you will be somewhere at -38 *C; just what you want it to be.
    * MK100
  8. The Following User Says Thank You to hid3 For This Useful Post:
    RedNix (19th October, 2018)
