Results 1 to 3 of 3
    Mar 2015
    Default ALFA ROMEO MJD8F2.A3 after swap DTC P0601
    Hello all i need some help on alfa romeo MITO , ECU MJD8F2.A3 , i put picture of original ecu and donator , my problem is original MPC is not readable , so i just swap eeprom car start but DTC P0601 , someone already have this problem or if someone have JTGA read of same original ECU , thank by advance
    Mar 2015
    Hi all problem DTC P0601 solved , only by write injector code if it can help another with this problem
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    can you upload the flash? i want to compare it with fiat same ecu...
    Thank you.
