Results 1 to 9 of 9
    sdnatlst's Avatar
    Aug 2011
    England
    Default freelander 2, why only 1 aftermarket remote per car? problem?
    hi i have a customer who wants 2 freelander 2 remotes adding
    however after i order 2 aftermarket remote from ebay, i see this on 3dgroup
    https://3dgroupuk.com/product/view/LRR9c
    it says
    NOTE:
    YOU CAN ONLY PROVIDE ONE REMOTE PER CAR ON THIS REMOTE. DO NOT ATTEMPT TO CODE 2 COPY REMOTES INTO ONE VEHICLE.
    does anyone know why this is a problem, what will happen if i try to add 2 aftermarket remote to the car? thanks!
    Oct 2015
    I guess that some bytes which should be unique for each remote are the same, which can cause problem.
    sdnatlst's Avatar
    Aug 2011
    England
    yes maybe thats right, i just wonder if it would fail to program 2nd, or it would make some problem for the car.
    P&D's Avatar
    original ok then add 1 after market key =2 working keys
    add a 2nd after market key to make 3
    1st after market key kicked out of the system
    still only 2 keys programmed
    Then waste of key after programmed its locked so used & door wedge ready for the bin
  5. The Following 2 Users Say Thank You to P&D For This Useful Post:
    rokibar (19th October, 2018), sdnatlst (18th October, 2018)
    sdnatlst's Avatar
    Aug 2011
    England
    Original key will start the car but will not operate central locking, so customer wanted 2 new keys,
    I will inform i can only add 1, because OEM remotes are really expensive.
    Any ideas why current key wont operate central locking anymore?
    Jan 2017
    USA ����
    Quote Originally Posted by sdnatlst View Post
    its broken.............
    P&D's Avatar
    Very Common fault here in the UK the Negative battery terminal snaps
    replace battery VL2330 remote will work again
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by P&D View Post
    I don't think it's common problem, because negative pin is more bigger than positive.
    So if VL2330 is inverted, it cannot fit the pin solder.
  10. #9
    P&D's Avatar
    I must of dreamed about fixing 100 of them all with the battery terminal snapped ?
