Results 1 to 3 of 3
    Oct 2015
    Default Km change and pin request
    Hello. Here is the dump from a Audi A6 cluster. Part number 8D0919880M. The eeprom is a ST 93c66. Can anyone change the km to 264000 and help me with the PIN code needed to adapt the cluster? I don't know if the cluster needs adapting, I saw a blinking immo light on it when connected to power on the bench so I assume it has. Thank you
    Jan 2016
    EU
    Here your file....
  3. The Following User Says Thank You to voyager2004 For This Useful Post:
    spitt (19th October, 2018)
    Oct 2015
    It worked. Thank you
