Results 1 to 8 of 8
    AvechuchoAxel's Avatar
    Downey, CALIFORNIA
    Default 2012 AUDI A7 MILEAGE CORRECTION HELP
    2012 AUDI A7
    95320
    ORI: 135,253 MLS
    NEW: 70,XXX MLS
    READ FROM EEPROM.
    Nicolas9's Avatar
    Feb 2017
    Aruba
    not possible this way
    Downey, CALIFORNIA
    You mean...only OBD?
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by Nicolas9 View Post
    is possible,you just have to know how, at least I do not know, steveleo yes.......
  5. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    sagie (19th October, 2018)
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by AvechuchoAxel View Post
    Or direct obd. Or else prepare eeprom then do obd.
    But you need proper tools. Anyway apparently steveleo has a 3rd solution, direct by eeprom, but don't know if he is going to reply here.
    Thanks Dr.zoidberg for info.
    Jul 2016
    Thanks for the flowers guys, but this is a bosch. The very very early ones (2010) you can be lucky that they work with eep preparation only, but usually these are full obd or at least obd + eep preparation. Dont know if you can read skey maybe on bench. Should work. But eep only i see no chance at the moment.
  8. The Following 3 Users Say Thank You to steveleo For This Useful Post:
    AvechuchoAxel (19th October, 2018), levisdj (19th October, 2018), sagie (19th October, 2018)
  9. #7
    brend's Avatar
    Oct 2015
    Same where
  10. #8
    Feb 2013
    UK Bristol
    Hi There guys.
    I will have work to do this in A7 2014. I have SMOK oryginal, but not for all VAGS cars, must check what support me at the momnet, i will have a look tommorow what support.
    I like ask in which module is stored Millage as well?
    How you do offen?
    Millage cluster, DPF reset, drive on each key minimum 100km/miles...
    need on ecu? on which other module is storred too and how is possible chance..
    My post helps you? Please Hit Buttons
