Results 1 to 12 of 12
    Aug 2013
    Spain
    Default CLIO II SIEMENS sirius32N immoff with A/C
    I need immoff for this ecu Engine 1.2, BMT N2 died and i only find a N3 all work less immo,i try program keys and the cars start for 5min then dont start more. Ref S110138000 B SIRIUS 32N. SW 8200059086 HW8200044437. No CAN, this is K-LINE, Here flash file 29f
    Aug 2013
    Spain
    I tried with 2 files through ecu decoding 3.2, the engine tries to start but it comes down
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by carsandkeys View Post
    What does it mean tries to start... Maybe ignition coil connectors fail.. Anyway try to this dump
    edit: cut immo line from pin 58 of ECU!!!
  4. The Following 2 Users Say Thank You to WinWoj For This Useful Post:
    ABD ERRAHMANE (22nd July, 2020), carsandkeys (22nd October, 2018)
    Aug 2013
    Spain
    Quote Originally Posted by WinWoj View Post
    Your file work 100%, cars start. thank you
  6. The Following User Says Thank You to carsandkeys For This Useful Post:
    WinWoj (22nd October, 2018)
    Sep 2016
    Hello ,
    Sorry digging up this thread but i dont want to open another one with the same topic.
    Can you send me the file or the password for this one ?
    If it is a tested and working solution
  8. #6
    Sep 2016
    Anyone , please ?
  9. #7
    Aug 2013
    Spain
    Quote Originally Posted by scummy View Post
    Hello ,
    You need do immoff to your original file or you will lose A/C. Post dump and maybe someone can help you... I bough renault ecu decoder too. this work great with all this ecus
  10. #8
    Sep 2016
    Here is my dump read with KTAG
    I've got immo decoder , but some members say that their solution doesn't work , or is it just for A/C cars ?
    Actually car doesnt have A/C , i've been told this right now
  11. #9
    belgrade,serbia
    Clio 2 1.rarhere you are cut pin 58
  12. The Following 4 Users Say Thank You to vladanr For This Useful Post:
    carsandkeys (19th July, 2019), krakkamal (28th November, 2019), Louislesinge (19th July, 2019), scummy (19th July, 2019)
  13. #10
    Sep 2016
    Thanks , let me try this and then i will report if it works
  14. #11
    Sep 2016
    Solution working , for anyone who needs this in the future
  15. #12
    May 2021
    Default Mechanic
    In my opinion, you should try to ask for a suggestion from a mechanic. I had a similar problem and I tried to fix it by myself, but as you understand I couldn't. So, I founded an aircon service near me which solved my problem. I hardly live when it's hot outside, that's why I always need a good air conditioner which saves me. I even have health problems connected to this. And sure, my productivity decreases when it's very hot outside. I don't understand why am so sensitive, but all my family has the same problem. I just think we should move to another country, but it isn't that easy.
