    electrones's Avatar
    Feb 2012
    Around C.V
    Default Fiat Stilo 1.9 JTD Immo Off, 0 281 011 396
    Hi friends
    I need immo off for this Fiat Stilo 1.9JTD, tested solution without U1600 if possible
    Thanks in advance
    CHeers
    Press "THANKS" button. just one click, CHEERS
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by electrones View Post
    Hi friends
    Thanks in advance
    CHeers
    Very bad read m8.Try to read again with other tool.
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  3. The Following User Says Thank You to baltazar3 For This Useful Post:
    electrones (22nd October, 2018)
    Autronico's Avatar
    Jan 2017
    ITALY
    The file is badly read
  5. The Following User Says Thank You to Autronico For This Useful Post:
  6. #4
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by baltazar3 View Post
    Quote Originally Posted by Autronico View Post
    Hi gyus
    I cleaned pads and read again i thing i have good read now,
    i tried to read by Fgtech but without success, can identify ECU numbers , i taked eeprom out of circuit but can not read flash
    Thanks in advance
    cheers
    Autronico's Avatar
    Jan 2017
    ITALY
    This is immo off with cks correct, I could not correct the error U1600, see if it suits you the same
  8. The Following User Says Thank You to Autronico For This Useful Post:
  9. #6
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    Thanks m8 worked
    Sorry for delay
    CHeers
