hi guys is posible add key in data. i dont have license for 4d id67. eprom is 93c66 x 16. i waiting you aswer.
thanks advance.
thanks advance.
This is a g-key, I don't think you can add data to transponder, you can emulate or write new transponder.
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
Here is ur immo reset file
Carkeysa (22nd October, 2018)
Just add 1 new master key by inserting it in the ignition. The security light should then blink once and go solid again. Then turn ignition on and off quickly 5 times to take it out of programming mode. Alternatively you can insert 3 keys, 2 masters and 1 valet key. Just insert then in to the ignition without turning on the ignition, the light will blink for each key and after the 3 keys are programmed the light will be off when you insert the keys again and it will automatically come out of programming mode.
clk1201 is posible add key file reset ? i have one key.
hi friend i solved chip g
