Results 1 to 14 of 14
    Mar 2012
    Default peugeot 407 2008 bsi killed by fvdi
    hello house,
    i am having a challenge with the subject vehicle. i tried reading pin code from bsi using fvdi. bsi got killed. i believe the flash is tdead as vehicle will not power up.
    can someone pls give me a good flash that will help remedy this situation?
    pls find attached a details as read by fvdi of the bsi.
    electronic control unit identification ---
    Functional Plan No: 9664058780
    Manufacturer: Johnson Controls
    Functional Product No: 9678476980
    Software Index: 05.02
    Calibration Index: 00.00
    Diagnostic Index: OR
    Serial Number: 010511
    Manufactoring Date: 12/8/2031
    System: B0
    Software edition: 11.54
    Software signature: 7A.D9
    Software reference: 9678093780
    Programming Date: 27/8/2014
    Reprogramming counter: 2
    chris
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    boot mode.
    Press Thanks and Reputation
    May 2010
    On printed circuits
    Just read the Eeprom 95128 I think and you have to read the ECU as well for the correct PIN code, post them and I will try to help.
    brend's Avatar
    Oct 2015
    Same where
    Flash corrupted .
    Just need good one flash..........
    Write this good flash and everything ok...........
    You can use fvdi for this.
    NB!!! Don't ask in PM old file password , Im not remember.
  5. The Following 5 Users Say Thank You to brend For This Useful Post:
    Marvin1993 (28th February, 2019), racin-snake (22nd October, 2018), rafal (20th October, 2018), rokibar (20th October, 2018), Weasel3 (20th October, 2018)
  6. #5
    Meat-Head's Avatar
    Quote Originally Posted by Kocta View Post
    boot mode.
    yeah the question be, how do one fix these that do it?
  7. #6
    Mar 2012
    Thanks for your reply. I will play around with fvdi and see the outcome. Problem is I don't know where write flash function is. But I will find out.
  8. #7
    Mar 2012
    thanks to all. vehicle is ok after writing the flash.
  9. #8
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by omolehina View Post
    For future!!!
    Use for thanks magic button...........
  10. The Following 3 Users Say Thank You to brend For This Useful Post:
    doctore (21st October, 2018), gege974 (20th October, 2018), rafal (20th October, 2018)
  11. #9
    Meat-Head's Avatar
    So how do you rewrite the flash?
  12. #10
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by Meat-Head View Post
    he has now completed the job
    and he escaped the next 6 years that would answer you
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  13. The Following 3 Users Say Thank You to doctore For This Useful Post:
    brend (21st October, 2018), tiguan (21st October, 2018), topclef (21st October, 2018)
  14. #11
    Mar 2012
    I used fvdi. Special function, ECU flaser, select ECU type, load flash, click update and wait for completion .
  15. #12
    Mar 2012
    Didn't escape. I appreciate your concern though.
  16. #13
    Mar 2012
    I also learnt to backup flash any time I want to perform any activity of this mature. It was really a trying time. But you guys are the best. Thanks for all the resourfulness
  17. The Following 3 Users Say Thank You to omolehina For This Useful Post:
    brend (21st October, 2018), Kayhan 17# (25th October, 2018), topclef (21st October, 2018)
  18. #14
    Junior Member HLEKTRONIO's Avatar
    Nov 2011
    Thailand
    Hi Omolehina,
    you used ECU function to write BSI?
