Same thing happens to me on with zed full.
Disconnect battery for 15 seconds, reconnect and everything back to normal
Sent from my SM-G965F using Tapatalk
Hello ! I have a problem with a Peugeot 407 / 2007. I tried to read pincode with fvdi 2015, then BSI died. No lights, wipers. I think the flash was erased. I found a dump in C://Abrites documents, but I think it's corupted. What solution do I have ? I can resolve this BSI, or I can adapt another BSI ? Sorry for my bad english.20181020_180050_001[1].jpg20181020_180050_001[1].jpg
FVDI will corrupt BSI JCI flash , don't use FVDI for BSI JCI .
attached original flash-dump 12C5 , write it and all will be ok
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
doctore (21st October, 2018), ramiz auto lock (21st October, 2018)
use ECU Flasher special function , choose BSI JCI , load flash and write .
It works very well. Finally the dash born again, and the engine start. Thousands of thanks. Thanks a lot.
I have another question. The client changed the dashboard (or instrument cluster I think named) with two others, and now he has a different mileage than original.
There is a safety solution to change mileage to original ? Can I use special function "CAN calibration " of fvdi ? Thanks a lot.
I didn't want to risk, I want to ask first.
