Results 1 to 7 of 7
Thread: Tprot or no?
    moky's Avatar
    Apr 2010
    Behind you
    Default Tprot or no?
    someone can say me if tprot on this file please?
    ecu edc17cp14 can write by obd?
    many thx !
    sdtsedat's Avatar
    Jan 2015
    Belgium
    What year?
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  3. The Following User Says Thank You to sdtsedat For This Useful Post:
    moky (21st October, 2018)
    moky's Avatar
    Apr 2010
    Behind you
    car year 2009
    Team dz's Avatar
    Apr 2017
    ALGERIA
    YES tprot Find 3C 2B
    Yes there are 63 times in the file
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  6. The Following User Says Thank You to Team dz For This Useful Post:
  7. #5
    moky's Avatar
    Apr 2010
    Behind you
    ok thanks a lot
  8. #6
    Aug 2012
    Quote Originally Posted by Team dz View Post
    how u see that in obd read out ?
    moky is the car before 6/2009 i´m 100%sure there is not tp inside also after update
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  9. The Following User Says Thank You to icezero2010 For This Useful Post:
  10. #7
    moky's Avatar
    Apr 2010
    Behind you
    its solved I did it in boot
    many thanks for help
