    Oct 2013
    Default Mercedes ML AAM module add key
    i made 2 new keys (7935 chips) from AAM module of Mercedes ML
    I read AAM with 1D69J mcu and i see with gambit that i have 1 and 2 keys slot used, i reprogram 1 and 2 slot with gambit programmer. Must i insert new 7935 in AAM dump or it directly start the car?
    can you help me ?
    in attached dump of AAM and key data
    thanks in advance
    Sep 2011
    Yes new.
    Yes it will start the car directly.
    Išsiųsta naudojantis SM-G950F Tapatalk 4 Lt
  3. The Following User Says Thank You to oficialusis For This Useful Post:
    Rebound (22nd October, 2018)
    Oct 2013
    I want avoid to desolder mcu many times, i will try tomorrow thanks
    Sep 2011
    It's possible to do it trought OBD if you use good tools.
    Oct 2013
    I know that with AVDI i can do job without read mcu...but i miss this device
    I hope that car start...i read that i must add Key with diagnosis or with Key programmer if i use empty Key slot
    I don t know if i use used Key slot the car Will start without add Key in aam
    Oct 2013
    Car start with key1 used slot and key3 empty slot without mod AAM dumpThanks
  8. The Following User Says Thank You to Rebound For This Useful Post:
    oficialusis (22nd October, 2018)
