Results 1 to 4 of 4
    Oct 2014
    Default 1T0 035 680B - White screen
    What to do in this case ? White screen after update
    1T0 035 680B
    HW: H03
    SW: 0900
    Reflash ST10 will help ?
    @EDIT
    SOLVED
    PM for more info
  2. The Following User Says Thank You to locarno For This Useful Post:
    markogr (18th September, 2019)
  3. #2
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I have problem with one of this units does anyone has sofrware disk for solving problem because in my case it is software problem ?
    Here to HELP!
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Does anyone has link for software update for 1T0 035 680 CX RNS 510 from passat?
    Sent from my TELEFON
    Here to HELP!
    Oct 2014
    Are you sure it is software problem ? In my case the problem was cold joints on front panel PCB. You can also check MAX1997E IC.
    You should replace front panel from another unit first.
    If it is software problem, I don't think you will repair this with "update cd". Then you need to desolder and reprogramm flash.
