Results 1 to 7 of 7
    Jan 2016
    Default water damaged iphone 6 restores but won't turn on
    I got this iphone with water damage. I opened it and sprayed the MB with dry contact cleaner. After reassembling it turned on and the only thing that was not working was the gyroscope, so I disassembled again and tried some more dry contact cleaning, now it does not turn on. The screen remains on the empty battery, it was 100% charged. Any clue?
    Oct 2018
    yes. put it in a bowl of rice to absorb humidity
    Jan 2016
    There is no humidity
    Jan 2016
    Solved: it was the battery
    VeryFastSnail's Avatar
    Jan 2019
    Guys, rice does not work... It will absorb such a small amount of moisture that it doesn't even count. Best way to fix water damaged Phone is to open it up and put motherboard in ultrasonic cleaner...
    If I helped you, feel free to drop me that sweet sweet +1 thank you.
    clusters's Avatar
    Mar 2015
    Canada
    Sure it does.....
    huskypt's Avatar
    Apr 2016
    PT
    unplug battery.... use spray eletronic special to remove humidity...
