Results 1 to 2 of 2
    Jun 2018
    Default Audi TT cluster replace 8j0920930
    has anyone a solution for me.
    A costumer came with a ,,new'' dash (it is used and Safe in the display) and i would like to learn it to his car with FVDI 2018.
    I read Pin / CS / MAC by ECU. Then i tryed to read config and immo data by dash. No communication because security acess faild.
    Then i used a trick and read the eprom 24c32 with a programmer, saved the dump and load a damage dump to it.
    After installation back in the car the display show DEF and i can write the org dump back via OBD.
    Now i can read config an immo data, but immo data locks like not good only the VIN is correct. I think fvdi decrypt eprom / micronas wrong. So i can't upload new immo data.
    After Dash reset it show Safe again.
    Can anyone tell me a solution or how to fix the problem with fvdi or something like that.
    Thaks in advanced
    Dec 2017
    Try write dump By programmer your Immo Date demaged But Immo Date in micronas
