Results 1 to 2 of 2
    Default Electronic REPAIRING IAW MAGNETI MARELLI 5SFX.XX INFOS NEEDED
    hi mates, i wonder if you can give me some informations.. i have an ecu 5SF4 with P0353, IGNITION COIL C PRIMARY/SECONDARY CIRCUIT MALFUNCTION.
    the IC that should send the spark is OK (vb325sp) , now i tried to backtrace where the input pin come from.. but couldn't find nothing, now i am supposing that it come directly from ST10F296
    Did you ever had a similar problem?
    Thanks for any hint
    Paul
    Feb 2013
    hi
    you have to have an ecu input pin
    watch the flash memory that is not corrupt
    I hope to help
    good luck
