Results 16 to 30 of 44
  1. #16
    Nov 2016
    @dkgti - 7570
  2. The Following 2 Users Say Thank You to Stopro92 For This Useful Post:
    dkgti (22nd April, 2019), jomberykaso (23rd April, 2019)
  3. #17
    Talleresmalaga's Avatar
    Nov 2017
    Espańa
    Quote Originally Posted by kubuswujo View Post
    Sorry i wanted to adapt new Ecu in car.
    I have old ecu and have readed Pin from it: 9949
    I have Tacho from car Pin is 9949
    I have new ECU that i want to adpadt its 1707
    And now, there is no problem to:
    reset old ecu,
    reset new ecu.
    write security code in tacho (obly for try if pin is ok)
    But when i go into Body immobilizer and try 9949 Pin i got a wrong security code
    Good afternoon, why do you change your ecu?
    if it is because the vehicle did not start, it could be problems with the cim module and it is not ecu problems and it continues with the error ...
    You can use carprog to read old ecu and modify the new one, without having to use opcom to pair
    Process:
    connect old ecu to the vehicle, put the contact, read with carprog, at the top, this eeprom, enter and save the reading.
    leave the screen open
    disconnect the contact, change the ecu and connect the scrapping contact and write
    the data of the pin and cinclonized must be cloned
    start the vehicle and have a beer to our health
    if you have a cloned ecus the problem persists change cim module
    regards
    If help is useful thanks+rep
  4. #18
    Jan 2019
    H iguys I need someone to help please I have a eeprom dump file from ipc corsa d 1.0 08 plate
    dump file attached . Thanks!!!
  5. #19
    Jan 2019
    Hi guys just extract the dump file from my IPC some one please can help me find the pin code from it ... file attached,
  6. #20
    Nov 2016
    Bad dump send dump tacho 35080
  7. #21
    kiszka's Avatar
    Quote Originally Posted by kcsaude View Post
    it is imperative to read the eeprom as 35080 !
    you can not help a person
    which does not listen to what is being said
    if it is difficult for you, then find yourself another job
    https://www.digital-kaos.co.uk/forum...-pin-from-dump
    https://www.digital-kaos.co.uk/forum...rsa-D-Pin-Code
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  8. The Following User Says Thank You to kiszka For This Useful Post:
    rafal (28th April, 2019)
  9. #22
    Jan 2021
    Szia.
    Kérem, segítsen, szükségem lenne egy biztonsági kódra.
    Opel corsa d 2007 vintage
    1.3 motorkód: DTH: z13DTH1768125 Kérem
    , segítsen ...
  10. #23
    brend's Avatar
    Oct 2015
    Same where
    Without dump only good luck!
    Quote Originally Posted by Tibi1983 View Post
    Hi there.
    Please help I would need a security code.
    1.3 Engine code DTH: z13DTH1768125
    Please help ...
  11. #24
    Jan 2021
    Unfortunately, what you wrote a link to is invalid.
  12. #25
    Jan 2021
    Itt van az olvasott fájl.
    Köszönöm a segítséget.
    Hello.
    Please help, I need a security code.
    Engine Code 1.3: DTH: z13DTH1768125
    Please help ...
  13. #26
    rafal's Avatar
    UK - PL
    post eeprom m8................................
    need help
    now my goal is to buy xp-005
    who will help?
  14. #27
    Jan 2021
    [QUOTE = rafal; 4052514] post eeprom m8 ................................ [/ QUOTE]
    What does that mean?
    Can't find the security code from here?
  15. #28
    Aug 2018
    Romania
    This means that the Security Code is stored in eeprom.
    You posted the contents of the flash ... maps.
    You need to read and put here the content of eeprom something like 95320
    Do not forget to press Thanks and Reputation buttons!
  16. The Following User Says Thank You to sebage For This Useful Post:
    Tibi1983 (1st February, 2021)
  17. #29
    Jan 2021
    [QUOTE = sebage; 4054239] Ez azt jelenti, hogy a biztonsági kódot az eeprom tárolja.
    Ön közzétette a flash ... térképek tartalmát.
    El kell olvasnia és ide kell raknia az eeprom tartalmát, például 95320 [/ QUOTE]
    Please explain. How to read? Where is it located?
  18. #30
    brend's Avatar
    Oct 2015
    Same where
    ENGLISH!!!
  19. The Following User Says Thank You to brend For This Useful Post:
    rafal (1st February, 2021)
