Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    Dec 2016
    Default OPEL CORSA D PIN from TACHO
    Can someone help with reading PIN code from tacho CORSA D?
    EEprom was 080D0WQ.
    Thanks in advance
    Kuba
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
    bank's Avatar
    Feb 2017
    Ukraine
    4999 or 9499
  3. The Following User Says Thank You to bank For This Useful Post:
    kubuswujo (29th October, 2018)
    Dec 2016
    i need this code to adapt new ecu in car i had new ecu and pin for new ecu i reset it its ok.
    But i try to type
    4999 or 9499
    In immo as security code and it is not working... pin should be same in tacho and immo module as i think...
    I tried several times but always wrong security code...
    Can someone check?
    EDIT:
    I found the right PIN.
    I read the PIN CODE FROM Instrument cluster using Autel via OBD. It shows:
    9949.
    Ok this PIN CODE works but only for Instrument cluster. But when i go into
    BODY>Immobilizer>Programing>Security code>>
    I always get :"Wrong security code" I must add that i do have oryginal OP-COM.
    In Instrument cluster PIN 9949 OK, but in Immobiliser not ok... ;/ ;/ ;/
    Is it possible that car has different PIN in immo and in Instrument cluster?
    Dec 2016
    I try to read PIN code from old ecu using CARPROG
    ecu is ME7 6.2 but carprog shows PIN:
    A3C4
    Immo sync data:
    33D6349A5F734C36383834307D6ABB45A3C480F05C383A55
    Is it possible that PIN has Letters not numbers?
    If i make read all it does try to read but after finish does not show anything.
    Read dump also same.
    "Searching unlock byte" and finish and noting new.
    Jun 2017
    Could you please let us know what you want to do ?
    If you want to change the dash, you need the security code from the new dash and for the old one ...
    Let us know your situation and I will try to help you !
    Dec 2016
    Sorry i wanted to adapt new Ecu in car.
    I have old ecu and have readed Pin from it: 9949
    I have Tacho from car Pin is 9949
    I have new ECU that i want to adpadt its 1707
    And now, there is no problem to:
    reset old ecu,
    reset new ecu.
    write security code in tacho (obly for try if pin is ok)
    But when i go into Body immobilizer and try 9949 Pin i got a wrong security code
    rafal's Avatar
    UK - PL
    have you tried reset by carprog?
    http://www.digital-kaos.co.uk/forums...h-cannot-reset
    need help
    now my goal is to buy xp-005
    who will help?
  9. The Following User Says Thank You to rafal For This Useful Post:
    frappes (29th January, 2021)
  10. #8
    super jumbe's Avatar
    Livingstone
    Remove old chip from old ECU and replace to new ECU....
  11. #9
    Dec 2016
    Here is an inside of ECU please tell me where here is EEprom?
    I cannot identify EEPROM here.
  12. #10
    Faraday's Avatar
    May 2012
    The dark side of the moon
    IMHO In this case best to read BCM for pin
  13. #11
    Dec 2016
    Ok, here is a BCM where here is eeprom to read?
  14. #12
    rob h's Avatar
    May 2011
  15. #13
    Nov 2018
    i use fvdi or carprog . what is ecu reference plz
  16. #14
    Livingstone
    Quote Originally Posted by kubuswujo View Post
    Sorry I thought this was Corsa D 1.3 CDTi
    .B.q.*........t.%.M:'...4....#.2. \J.i. e}...V.iن&.t.%.M:'...4....#.2. \J.i. e}...V.iن&B9994..0W0LDS6L88044147.0........B 9994..
    0W0LDS6L88044147.0................................ ..KJKJ
    Prited 9994
    Converted: 9949 if it came from the same car live ignition on for 40min should let you go in.
  17. #15
    May 2018
    Greece
    Default Pin code
    can you help....i need pin code uploaded file is dump from instruments
