Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Mar 2011
    Default problem to clone edc16cp34 (0281014406) audi q7
    Hi friends.
    I have the ecu(0281014406) edc16cp34 hw04 of an audi q7 that has gotten wet. Previously I had a full bdm copy of that ecu. I have bought another compatible (0281013684) edc16cp34 hw05, and I write the eeprom, mcu, flash. In theory it is copy and paste. The problem is that the q7 does not start.
    I do not know if I have to make an equalization, between the ecu, and other unit, as in bmw.
    I do not know how to solve this.
    I upload 3 file,eeprom, flash,mcu. and eeprom new ecu hw05
    Thanks...
    dijo's Avatar
    Apr 2010
    Quote Originally Posted by alcorte View Post
    Hi friends.
    Thanks...
    Here is your new eeprom:
  3. The Following User Says Thank You to dijo For This Useful Post:
    alcorte (31st October, 2018)
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Mar 2011
    why do you say ? I will test the partner's solution tomorrow.
  6. #5
    Mar 2011
    the "new ecu" is break.
  7. #6
    Mar 2011
    I have bought another "new ecu " compatible (0281012705) edc16cp34.
    Somebody can help me to clone this ecu.?
    Thanks...
  8. #7
    Mar 2011
    I will try with immo off by aetool. The new ecu,I think than isn´t compatible to clone.
    My original ecu 0281014406: Ecus compatibles:EDC16CP34-4.8
    0281012772
    0281012919
    0281013076
    0281013188
    0281013189
    0281013262
    0281013263
    0281013298
    0281013319
    0281013320
    0281013678
    0281013679
    0281013684
    0281013688
    0281013689
    0281013690
    0281013691
    0281014406
    0281014407
    0281014408
    0281014409
    0986283395
    0986283396
    0986283397
    0986283398
  9. #8
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  10. The Following User Says Thank You to kiszka For This Useful Post:
    alcorte (14th November, 2018)
  11. #9
    Mar 2011
    I have try immo with aetool (eeprom new ecu 0281012705) edc16cp34 and The car dónt star.
    I think than isn´t compatible new ecu. although both ecus are similar. but esitronic, He tells me that they are not compatible.
    The vin the car is WAUZZZ4L58D011311
    Thanks advance
  12. #10
    Mar 2011
    someone, pleas?
  13. #11
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  14. The Following User Says Thank You to kiszka For This Useful Post:
    alcorte (15th November, 2018)
  15. #12
    Mar 2011
    I already have the empty mailbox, would you mind sending me the code.
    Thanks.
  16. #13
    Mar 2011
    kiszka, the car does not start. I upload the photos of the errors. The ecu has the vin of the car. But it does not start. I do not know if it is because the ecu is not compatible. Or I have no idea. I'm already getting desperate. Thanks for the help.
  17. #14
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  18. The Following User Says Thank You to kiszka For This Useful Post:
    alcorte (16th November, 2018)
  19. #15
    dijo's Avatar
    Apr 2010
    Have you immo in the dash or in BCM, post all you data if you have BCM then eeprom and flash...
    How you will be helped and don't provide all info and data...
  20. The Following User Says Thank You to dijo For This Useful Post:
