test and report
test and report
baubynis (31st October, 2018)
not starts, only cranking
Or some one can get pin code, or immo off?
vin nr WPOZZZ99ZTS330530
car not starts after low battery
no one from remote control not working
does this car have a alarm system ?
usually there is sticker on door glass that states "porsche alarm system"..
are remotes for lock and unlock small square ones with 2 buttons ??
immobiliser in this old 993 blocks spark and cranking.
half of the code is what remote sends, other half is in body module which is under drivers seat.
module you have sent pictures of is immobiliser unit, which works apparently hence car cranks.
if remotes are dead, you can not order new ones.
what you can do is to add 3rd party remote receiver in the body ecu and use this 3rd party remotes to lock and unlock the car.
I rewired 2 cars in such a manner and both are working flawlessly for a few years now.
I used remotes with receiver from Italian company "spal"....30 eur complete set (you can choose positive or negative commands)
you should install receiver inside body module so that it directly command relays for lock/unlock.
luckily this old body sets alarm to armed or disarmed based on statuses of inputs, hence code in original remote is just that,,code for remote.
only difference in this setup compared to original is that because of pulse length sent by receiver, user has to sometimes press the button on remote twice,
which does not make any difference in function but is rather just slightly inconvenient.
I tried to immo off this car then for a while, but without any luck.
br,
saso
baubynis (2nd November, 2018)
Yes My car have alarm is 1996 model ,
remote controls is 2 pieces (both is stop working after battery was low ) with one button with bend metal key you can send me email ,can send you more pictures .
Car do not have ignition immobilizer ring only was need to get re-lock car to get start the car
tried immo off but not working tried get read central locking ecu mcu(location under passenger seat part nr 928 618 260.03)but no luck ,key fobs have eeprom inside 93c46.
Tried lock and unlock from central locking by giving negative signal to lock unlock to relay by the board but car not starts ,so know need help from you how to fix it .
Please help because I do know what to do next.
TRIED TO GET PIN CODE BUT LUCK.
try to unlock directly with probe lamp on some point in ecu under seat pulse it with probe lamp one end on negative and give puls to relays for unlocking in some order fast and slow try thjat
http://www.digital-kaos.co.uk/forums...=1#post1821017
http://www.digital-kaos.co.uk/forums...=1#post2030172
Try this and please report,
baubynis (15th November, 2018)
