Originally Posted by
drkyra
Yes, this one. EDC15+ECD16 i have good results. and yes, OBD. Need maybe 5 Minutes, if tool say "turn ignition off" - it count 30 seconds, then turn ignition on - finish.
If there is one failed, then VCDS is also not able to read current mileage.
Yes, the dash killer. I only use for EDC. Never kill a EDC. If not possible to read or change - nothing changes, no problems.
How? Like all other tools. Turn ignition on, Plug Tool with OBD, chose "mileage correction", chose "EDC". Then i chose EDC15xx oder EDC16xx, an press enter, and follow instructions on screen. Normaly it detects ECU, read mileage, and you have to enter new mileage. After a few minutes, the tool tell you to turn off ignition. Count 30 seconds down - turn ignition on - and press enter on tool. Reread with the tool - ok. Read after correction with VCDS - ok. (NOT ALL, i think, 80% it work. And it is a little bit faster then other tools i have for this... Even faster then digiprog, an more Versions covered then with digiprog)
English is not my first language...sorry
