DIGIPROG HELP - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: DIGIPROG HELP
  1. #16
    Mar 2013
    Europe
    Digiprog cant do EDC16 with 1.9TDI Engine!
    Only do it EDC16 2.0TDI ;-)
    Best to read & write ECU EEPROM is FVDI !
  2. #17
    Nov 2018
    Quote Originally Posted by drkyra View Post
    Yes, this one. EDC15+ECD16 i have good results. and yes, OBD. Need maybe 5 Minutes, if tool say "turn ignition off" - it count 30 seconds, then turn ignition on - finish.
    If there is one failed, then VCDS is also not able to read current mileage.
    Yes, the dash killer. I only use for EDC. Never kill a EDC. If not possible to read or change - nothing changes, no problems.
    How? Like all other tools. Turn ignition on, Plug Tool with OBD, chose "mileage correction", chose "EDC". Then i chose EDC15xx oder EDC16xx, an press enter, and follow instructions on screen. Normaly it detects ECU, read mileage, and you have to enter new mileage. After a few minutes, the tool tell you to turn off ignition. Count 30 seconds down - turn ignition on - and press enter on tool. Reread with the tool - ok. Read after correction with VCDS - ok. (NOT ALL, i think, 80% it work. And it is a little bit faster then other tools i have for this... Even faster then digiprog, an more Versions covered then with digiprog)
    English is not my first language...sorry
    Hi, received my super vag blue kcan. Done 1 2008 ecu mileage today, no problem, then done another 2008, again no problem both edc16x, dont them easily and fast. then tried to do a 2005 t5 edc16xx. reads mileage, goes to write then wont do it, tried edc15xx. it wont even read it.
    a friend told me ecu mileage can only be done from 2006+ by obd. has anyone any ideas what tool can do ecu mileage on 2003/4/5/6 t5 by obd.
    i have no problem using digiprog to do clocks. but wont work on edc. my blue super vag will do 2007/08 but not 05 and only some 06. thanks
  3. #18
    Nov 2010
    Ok, sorry. Hope its not wasted money for you....
    I dont know further (cheap) tools, that covers more edc 15+16.
    AFAIK someone use succesful VAG Commander cable 1.4 oder 3.6 for EDC15
    I dont have this - so i can nothing tell about it (if it works or not ?)
  4. #19
    Nov 2018
    No its not wasted money, will be perfect for me but need another for edc15. Ordered the commander cable and wait for it to come an try it. thanks again
