Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: DIGIPROG HELP
Hybrid View
    Nov 2018
    Default DIGIPROG HELP
    Hi their, i specialise in Volkswagen transporter vans t5 2003-2009 for customers.
    When i change mileage through obd port does dashboard no problem, when i try to the ecu through obd. it reads it, then i write the mileage. takes a while goes through the procedure and then when finished reads it and its the same miles from before.
    Is their another computer out their what can maybe do ecu correction through obd port for t5 transporters?
    Maybe my digiprog3 is broke? its a clone but does lots of dashboards
    Thanks, really appreciate it
    Nov 2018
    Anyone help or suggest?
    panos_k's Avatar
    Feb 2010
    GR pankar
    Disconnect the battery and connect again.
    May 2016
    Use vag dash can or fvdi.
    Nov 2018
    Quote Originally Posted by naprawa5 View Post
    Will they do the ecu as well as clocks? my digiprog does clocks no problem but wont do ecu. thanks
    Nov 2018
    Do you reccomend vag dash or fvdi, which is better, and will they do edc / ecu on vw t5 transporter by obd? thanks
    Feb 2010
    In EEP
    for edc15 and edc16 is best smok but all tools use same seed key and protocol for access to eeprom and flash area. if dont work one device it is little change work another.
    Nov 2018
    Quote Originally Posted by vasa View Post
    Hi , thanks yes but i do want a cheapish tool what will do edc on t5 2003-2009 easily by obd. thanks
    Nov 2010
    Quote Originally Posted by t5odometerfix View Post
    So your saying this tool - https://www.ebay.co.uk/itm/New-Super...-/222929521953
    Will do edc on a vw t5 from 2004 - 2009 by obd? im interested tell me more...
    Yes, this one. EDC15+ECD16 i have good results. and yes, OBD. Need maybe 5 Minutes, if tool say "turn ignition off" - it count 30 seconds, then turn ignition on - finish.
    If there is one failed, then VCDS is also not able to read current mileage.
    Quote Originally Posted by sagie View Post
    the blue one, the dash killer? you use it to change km in ecu, please tell how
    Yes, the dash killer. I only use for EDC. Never kill a EDC. If not possible to read or change - nothing changes, no problems.
    How? Like all other tools. Turn ignition on, Plug Tool with OBD, chose "mileage correction", chose "EDC". Then i chose EDC15xx oder EDC16xx, an press enter, and follow instructions on screen. Normaly it detects ECU, read mileage, and you have to enter new mileage. After a few minutes, the tool tell you to turn off ignition. Count 30 seconds down - turn ignition on - and press enter on tool. Reread with the tool - ok. Read after correction with VCDS - ok. (NOT ALL, i think, 80% it work. And it is a little bit faster then other tools i have for this... Even faster then digiprog, an more Versions covered then with digiprog)
    English is not my first language...sorry
  10. The Following User Says Thank You to drkyra For This Useful Post:
    sagie (17th November, 2018)
  11. #10
    Nov 2018
    Quote Originally Posted by drkyra View Post
    Just ordered this one - https://www.ebay.co.uk/itm/263576797817
    Just hope it will do all t5's ECU mileage from 2003-2009 by obd
    Thanks for your help dryka
  12. #11
    Nov 2018
    Hi, received my super vag blue kcan. Done 1 2008 ecu mileage today, no problem, then done another 2008, again no problem both edc16x, dont them easily and fast. then tried to do a 2005 t5 edc16xx. reads mileage, goes to write then wont do it, tried edc15xx. it wont even read it.
    a friend told me ecu mileage can only be done from 2006+ by obd. has anyone any ideas what tool can do ecu mileage on 2003/4/5/6 t5 by obd.
    i have no problem using digiprog to do clocks. but wont work on edc. my blue super vag will do 2007/08 but not 05 and only some 06. thanks
  13. #12
    Nov 2010
    good results on t5 with ultra cheap super vag k+can (the blue one)
    (but be careful, i only use it for edc. Better dont use for dashboards. Very bad on Golf 4, T4, Audi a3.... )
  14. The Following User Says Thank You to drkyra For This Useful Post:
  15. #13
    Nov 2018
  16. #14
    Jan 2016
  17. #15
    Jan 2016
    ok, i thought you talking about older blue supervag
