Results 1 to 4 of 4
    Aug 2013
    Default Alfa 147 edc15c7 immo off
    I need an immo off working solution for Alfa 147 diesel (2003)
    The car:
    EDC15C7 1.9 jtd 116Hp
    Hw: 0281011488
    Sw: 1037369116
    29F400
    The engine did not start.I flash one immo off file, but it's not working
    Now the car is started, but it gives an immo error in the instrument panel and gives U1600 dtc in ecu.
    The accelerator be moved causes a engine fault on the instrument panel, but no DTC in the ecu.
    THANKS for any help!
    Thanks, regards
    Aug 2013
    This ecu is enough to modify the 29F400 for full immo off?
    Volker's Avatar
    Try this Dump
  4. The Following User Says Thank You to Volker For This Useful Post:
    Bedik (15th November, 2018)
    Aug 2013
    This is another software version
