hello, I'm d-flasch / to my frm3r pl3 6135 3456588-02 anyone help me? thank you I can not repair:esmagado:
mini r56 .tank
thank you friend but it does not have to be the same
art64 (30th October, 2020), ecu reset (16th April, 2020), mariusz971 (13th November, 2019)
hello my friend
just push any dflash inside to make alive. Make eeprom from that dflash. then put it back in car and flash it via obd to car. after that code to accept VO (vehicle order )
DONE
BMW FOREVER
lolo241 (11th November, 2018)
My best experience with FRM repair dump is from Alexandr.
For 25usd i have received a FULL working file. Without any error or fix by diagnostic.
http://frm3.ru/
Youtube video: https://youtu.be/vmu88dWuyCc
100% working solution.
we are here to help. I understand that every tool cost but if you are good mech/elec you have enough from your garage. if you dont than close and change job.
if someone need help about FRM i will help for FREE.
BMW FOREVER
lolo241 (18th November, 2018)
I'm not seller, I'm not devloper.
I'm only a guy who haven't much time to lose on test 10 files and solutions. It's why i prefere to pay 20usd for a working solution on first test.
Ok we are here to help, but If you don't make any investment in tools for your garage You are going to meet a big problem with expand you garage services.
talk2idris (14th November, 2018)
Hi, can anyone help me with this module? It's just a favour for my friend. BMW Mini R56, EEE seems to be corrupted. I read P-Flash and D-Flash, I extracted EEE from D-Flash using some program from forum but got this result:
I flashed it anyway and tried in the car and it still doesn't work, there's no communication with FRM3R PL3.
D-Flash may be corrupted but it's definitely not my fault, I read it with Xprog and verified a few times.
D-Flash attached.
As always I'm happy to pay for help.
If D-Flash is really corrupted maybe someone can send me some other D-Flash file for that car.
Thanks in advance.
no advertising in sigs !!!
Could someone help me?
I would need an EEE for the following serial: R56 HIGH EKS 35 FRM3R PL3 6135 3456952 01 23994322 SW155031 HW11 5324828Q5.
The car is a Mini Countryman.
Thanks & Regards,
David
dfelten (28th February, 2021)
Hi Ricked,
Thanks for your answer.
The problem is that the d-flash is corrupted (I saw that when I extracted EEE from D-Flash using some program, I used XProg ro read it).
Is there any way to fix this or do I have to buy an other FRM?
Thanks,
David
