Somebody have an idea?
Hi everybody! Mercedes w211 after corrention only on dashboard show 2 messages : emissions inspect....
I tried to reset it from the dashboard and das, but still swears for maintenance.
I read ZGW on FVDI and tried to fix the services, there is also no result.
Somebody can help me? Maybe by engineer menu I can correct or disable this function?
I give the orig ZGW dump, maybe it is damaged?
The car have a Comand Aps?
If Yes you have to correct the date too in the comand Aps
Try this
what cgw part number ? I would try another CGW dump and do SCN coding and hope for the best. I edited assyst on w211 with FVDI, have random errors too after gateway edit, will try another CGW on the car in few days and see how it goes. On some w211 EIS dump can get corrupt too and cause funny issues (like taxi option ).
I think you just have to give new date to emission inspection in instrument cluster service menu..
I got same problem, on this model you should do from cluster with buttons, check on youtube for procedure
It can be dash problem there , I had many cases tryed every think on CGW without success . Try to recode dashboard with Star.
I cant solve the problem. I want write new flash\eeprom zgw.
