For clusters from models 2002-2004 I´ve removed the blue coating with acetone or toluene. Then removed mcu with hot air, cleaned the legs with fresh solder and cleaned the pcb pads. Clean the pcb from resin /flux, resolder the mcu with flux and resolder the resistor nets.
Should work 100%
Power up in bench with emulator or get a couple of CEM-units, wire them up and then gauge test via obd is possible.
